It is currently Thu Aug 07, 2025 7:43 am
PostPosted: Mon May 18, 2009 9:37 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Just curious if it is safe to string up a bolt-on neck prior to gluing. This would be just temporary to check intonation and playability prior to finishing. I use Martin precut necks with a single bolt on M/T joint
thanks
Richard
PostPosted: Mon May 18, 2009 9:50 am
Last Name: Hodge
Yes! I use these from StewMac to attach the bridge.
Bill Hodge
PostPosted: Mon May 18, 2009 11:04 am
thanks
Richard
Prior to gluing which part? Fretboard extension? Bridge?
PostPosted: Mon May 18, 2009 11:31 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Hi Pat sorry i was not clear. I am referring to the actual gluing of the neck and FB extension not the bridge.
thanks
Richard
PostPosted: Mon May 18, 2009 11:37 am
Last Name: Hodge
Howdy Richard,
I suspected that's what you meant. That's why I suggested the bridge bolts. That way you can disassemble everything easily to apply the finish after initial setup and intonation. Then once everything is finished and the final assembly /glueup is done, you can do the final setup and intonation. :D This is the way I do it and it works well. I use bolton necks exclusively.
Bill Hodge
PostPosted: Mon May 18, 2009 11:53 am
Hi Richard
If you're using a bolt on neck then there's no need to glue it in at all.
Also, you don't have to glue down the FB extension either. the pull of the strings will keep it nice and snug.
I recently strung up a guitar (a few months ago) without gluing the FB and I have had no problems at all.
Mat
PostPosted: Mon May 18, 2009 12:32 pm
I agree with Mat. One of the main advantages to bolt-on neck, IMO, is to eliminate the need for gluing the joint. The fretboard extension should be glued, though my main player, my first guitar that I built in
'05 still has the fb extension not glued. Anything that goes to a customer should, of course, have the extension glued, if it's designed for that.
PostPosted: Mon May 18, 2009 12:34 pm
Matthew Jenkins wrote:
<snip>
Mat
Gee Mat, no problems without gluing the fretboard?! That's great! :D
PostPosted: Mon May 18, 2009 1:06 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Thanks for the info, WOW I had no idea you did not need to supplement then bolt-on joint with glue
Thanks again
Richard
PostPosted: Mon May 18, 2009 1:28 pm
<snip>
Mat
Point taken :oops: laughing6-hehe
PostPosted: Mon May 18, 2009 1:56 pm
Since it is a Martin neck, it has only one bolt. Martin does glue the mortise into the neck block with these kind of necks, so I am not sure I would just leave it without glue. All of the bolted necks of which I am aware use two bolts and don't need glue. I would be careful.
PostPosted: Mon May 18, 2009 2:34 pm
I think the single threaded insert in a Martin dovetail neck is to attach the holding device for finishing not for attaching the neck. John at Blues Creek would know.
TJK
PostPosted: Mon May 18, 2009 2:47 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Thanks again
Richard
Like others have said, that particular joint is designed to be glued. Again, like others have said, I'd ask John Hall. (Bluescreek)
PostPosted: Mon May 18, 2009 3:41 pm
Oh, I missed the single-bolt part. I figured it was two bolts. With only one, it would be pretty fragile with the strings slack.
PostPosted: Mon May 18, 2009 4:04 pm
Last Name: Hodge
Yep, I missed the "single bolt" part too. I thought it was a bolton M&T neck. duh
Bill Hodge
PostPosted: Mon May 18, 2009 5:10 pm
Bill Hodge wrote:
It is, but not a bolted dovetail.
PostPosted: Mon May 18, 2009 6:41 pm
Last Name: Hodge
Did I say dovetail? I guess I missed that part too. :) I was imagining a two bolt M&T joint. A single bolt as was mentioned by others is typically used with the added support of glue, or at least this is what I've been told I've never used that type. I can't say one way or another that a single bolt will offer enough support for the need expressed in the original question. idunno I'm not qualified to answer that one since I make my own 2 bolt butt mount and M&T necks, but it looks like others have. :)
Bill Hodge
PostPosted: Mon May 18, 2009 7:28 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
just curious if I can just add another bolt to the martin necks, so that there are two bolts?
Richard
PostPosted: Mon May 18, 2009 10:08 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Richard
Make sure you support the side of the tenon, or else the wood will crack.
Typhoon Guitars
PostPosted: Mon May 18, 2009 10:47 pm
Richard
That works. The FB extension should still be glued if it's a customer's instrument. One bolt is OK if you're only going to check intonation, so long as the rest of the joint, the face of the heel in particular, is good.
Users browsing this forum: zmp2 and 38 guests
